Router for fibre
sticksman
Router for fibre
I want to buy a  router to optimise my new fibre service, I will be using wifi mainly but do have a powerplug connection to one device. Can anyone recommend a good model and tell me how difficult it would be for a layman to install and configure. Thanks.
PhyllisTyne
Re: Router for fibre
I think the Asus RT-N66U  is a bit of a favourite on here
shure
depends a lot on your budget and personal situation.  I chose the Asus RT-N66u as it had a reputation for high performance and good stability, which was important to me.  It's also very easy to set up and manage.  But it costs around £100, so may not be for everyone's taste.
sticksman
Is it plug and play or are there settings I have to configure, I am a layman!
shure
It's pretty much plug and play.  I'm on ADSL so the settings are different but I think the only thing you have to do is put your Plusnet username and password in and you're good to go.  Perhaps someone on here with the Asus on fibre can confirm?
Fixes: 20
I just bought the TP-LINK N600 TD-W9980, its a combined router so no bt modem needed.
Can't say how good it is as I haven't received it yet ;-)
But at ~£75 its cheaper than the Asus, and has good wifi, separate 2.4 & 5Ghz @300Mbs each.
PhyllisTyne
I'm probably moving to fibre but from what I have read it seems safest to use the openreach modem as supplied and stick a decent router on it.
Fixes: 4
No, it's not plug & play like the PN supplied router. I use the cheaper Asus RT-N56U which has the same features & GUI as the 66. You do have to go through a set up procedure when you first connect it to your computer & modem. However, even as an OAP I did find it to be very straightforward. The on line manual is clear & concise & the initial set up procedure intuitive.
Fixes: 20
I have been using the TG589 for over a year, it is a combined router and I have had no issues relating to speed etc using it, it is only that it is starting to play up that I am replacing it.
With it I can get stats if I want them about my vdsl line, which you can't get with the BT modem unless you unlock it.
kitz
Quote from: Hairy
TP-link TD-W9980 review - Stats are very basic :/
This is the all in one unit I use Zyxel WMG8324-B10A review
Unfortunately I wasnt able to get my mitts on a TG589 as I was a bit slow off the mark when PN asked for trialists.
PeeGee
Perhaps you should change the reference to the VMG8324-B10A in your review Shocked Roll eyes     Zyxel may not like TP-Link fixing bugs Wink
Phil
Corrected error!!
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
Fixes: 20
As I said I ain't really interested in the stats but they are there if I want them. Other reason for this one over the TG is the Gib ports and much better wifi.
kitz
Thanks vm PeeGee good spot. .  Now corrected.
sticksman
Thanks guys, I must read that the Asus modems aren't working well with Airplay which I use a lot, any other recommendations?
