Router flashing orange
james9494
Hi there, this had been an on and off issue for about a week, it was intermittent at first and now it's almost all the time. Our router will just constantly flash orange and we can't connect to the internet. I've tried a lot of fixes to kick start it, a couple worked but it goes back to flashing orange after a while and now nothing works.
Fixes: 55
Re: Router flashing orange
I've just been looking into this and noticed straight away that the line has been stable for the past 40 hours or so, how are things looking on your side?
 Adam Walker
james9494
Hey,
Waited a bit longer to reply in case it started playing up again. It's been working fine since I called you up on Sunday.
Fixes: 55
Marvellous! Cheers for letting us know.
 Adam Walker
