Router facilities
- Router facilities
Router facilities
26-08-2020 4:01 AM
Just signed up.
What router is being supplied atm? Does it support NAT loopback?
TIA
Previously - Shell, NowTV, Sky, EE, New Call Telecom/Fuelbroadband, Plusnet, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Re: Router facilities
26-08-2020 6:19 AM - edited 26-08-2020 6:20 AM
26-08-2020 6:31 AM
Ok I actually cheated and did a quick Google (as we all do), but from this thread of the BT forums it appears it is possible.
Never tried it, so I can't help any further really.
26-08-2020 7:31 AM
Cheers for that.
Maybe something they could add to the info page. Or maybe not? Just another thing to go wrong?
26-08-2020 7:34 AM
Thanks.
Knowing the router helps. I am assuming there is no HH5; just a HH5a?
26-08-2020 8:51 AM
For ADSL Plusnet supply a Sagecom 2704N. Fibre customers get a Hub One, which has BT Home Hub 5A hardware (note that there is also a HH 5B but that is not used) but tweeked Plusnet firmware which might influence whether it will do what you want.
26-08-2020 9:15 AM
Thanks for that.
Found
https://www.ispreview.co.uk/index.php/2015/01/isp-plusnet-launch-faster-hub-zero-2704n-broadband-rou... yet to establish if it does NAT loopback.
26-08-2020 9:26 AM
Going on https://community.plus.net/t5/ADSL-Broadband/Technicolour-versus-Sagem-2704n/td-p/1311503 looks like I'd be better off sticking with my 582N. Unless anyone can explain/solve the issues?
26-08-2020 10:39 AM
If you read this it might confirm this view, especially this sentence
These are some of the worst speeds we’ve seen from any router.
https://www.expertreviews.co.uk/plusnet/1403635/plusnet-hub-zero-2704n-review
26-08-2020 11:41 AM
Thanks.
I don't know why they bother sending out these routers if they are as bad as the reviews say. Perhaps most won't have any experience of alternatives or they just like clogging up their complaints channels with customers with slow connections?
