Router error stats 14/12/2011
- Router error stats 14/12/2011
15-12-2011 12:05 PM
Below are my router stats for yesterday afternoon.
It was very wet and windy,
Is this amount of errors something to be worried about?
I restarted the router just after this as my connection seemed to have hung!
Thanks, Mark.
Uptime: 0 days, 7:56:27
14/12/2011 20:20
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,148 / 11,312
Bandwidth (Up/Down) [kbps/kbps]: 1,160 / 11,350
Data Transferred (Sent/Received) [MB/MB]: 22.27 / 79.42
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 18.5 / 33.5
SN Margin (Up/Down) [dB]: 5.5 / 1.5
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 53 / 0
FEC Errors (Up/Down): 277,521 / 76,363,598
CRC Errors (Up/Down): 1,313 / 162,621
HEC Errors (Up/Down): 1,818,558,478 / 2,267,815
Thanks, Mark.
14/12/2011 20:20
Message 1 of 2
(555 Views)
1 REPLY 1
Re: Router error stats 14/12/2011
15-12-2011 1:44 PM
Hi micromark
I see you have started to raise a fault but it looks like you need to go back and answer some more questions. Have you changed filters/router tried test socket? Your connection graph below is showing quite a few drops.
Jojo
Jojo
Message 2 of 2
(275 Views)
