Router drops on incoming call
- Router drops on incoming call
29-06-2020 5:59 AM
My partner had a new line put in with BT last Tuesday and contract for with plusnet for internet provider.
So there have been a few drop outs with the router indicating with the classic orange light. Having said that is has been quite stable since the install of five days ago. However, I made a discovery last night which on my research seems to be common. I tried ringing in last night and the router dropped its connection. I tried this half a dozen times and sure enough it dropped out every time. The router was then stable for the rest of the evening.
Now , it’s a new installation and I really need to get this sorted. The BT line comes into the house into a main socket.The engineer said to me his advice was to use that socket as a junction box unless I particularly wanted it live. Thus I don’t have the facility to remove the face place isolating every thing else . It’s wired straight through to a new socket downstairs with built in filter, the cable is new. I’ve read and tried an extra filter to no avail. My research tells me it could be a high resistance on the Bt line, poor or corroded connection etc
I need some advice on how to tackle this as I don’t want to get into a to and fro thing over many weeks. Ideally I would like BT to check the line physically back to the local fibre box , connections , jelly crimps etc. When I ring plus net I don’t want to be told check this, replace the filter, could be a faulty faceplate etc, it’s a complete new install from the BT pole to the router.
What is your advice
Roger
Re: Router drops on incoming call
29-06-2020 7:14 AM - edited 29-06-2020 7:21 AM
I think the only thing you can do is test the test socket, which means taking off the faceplate off the master socket.
If it makes no difference, then you will have to raise a fault.
You could also try a 17070 option 2 quiet line test to see if there is any noise on your line.
EDIT: Also do you have a different router you can try, to rule out it being a dodgy router?
29-06-2020 9:43 AM
I have tried another router as I don’t have one. The install is only 5 days old and I feel at this moment it hasn’t passed it’s acceptance and is not fit for purpose at the moment. Good on the quiet mine test.
29-06-2020 10:27 AM
So that means you haven't?
Fair enough, just if you have a spare it worth testing it to rule out a hardware fault your end.
29-06-2020 10:53 AM
Could you open the 'main socket' (junction box) and tell us exactly how it is wired, what is connected to what?
Then the 'new socket downstairs' is that an NTE with a removable front filter faceplate? And how is that connected? Is everything clean and dry?
What I would hope to see is
incoming drop wire - 2 jelly crimps - one pair of internal cable - NTE backplate A and B - NTE filter faceplate - router.
Any other wires teed off, especially a 'bell wire' would be concerning.
29-06-2020 11:14 AM
Thanks for getting back to me
Roger
29-06-2020 11:21 AM
The box down stairs : the engineer said I could use that the same as a main box by removing the front for isolation. There will be no water ingress, it’s only been in five days and it’s all new, cable and boxes . I will check tho to make sure that there is nothing obvious. I think being an engineer , albeit in electronics rather than BT, I’ve over seen the job and I think I may have convinced myself that it’s a high resistance somewhere in the BT system but I take your point and will double check things .
Roger
29-06-2020 10:02 PM
Roger
03-07-2020 12:28 PM
Take care everyone
Rog
10-07-2020 10:53 PM
It had been quite stable for 5 days then it Went again . Engineer told me today that there is a 200 pair cable in a duct which is faulty but duct is blocked , he has found a good pair and hoping for the best.
R
11-07-2020 11:01 AM - edited 11-07-2020 11:04 AM
Sync dropping on incoming call (on an ADLS service - which is where this post has been made...) is usually caused by a faulty filter or a faulty line card in the exchange. You might not yet be out of the woods.
HOWEVER "the result was that the download speed has doubled from 15mbs to 32 mbs and no router disconnection" suggests that you might be on FTTC - in which case this is on the wrong board and there is some risk that you'll receive inappropriate advice!
11-07-2020 11:24 AM
We had already replaced the filter twice to eliminate it. BT found a definite fault and nothing to do with our internal equipment. They actually found a few faults the last one being a faulty 200 pair cable which really needs replacing but the duct is blocked but they did find one spare pair in the meantime. The speed has reduced from 35 to 27 but we can live with that as long as it’s stable.
11-07-2020 11:40 AM
FTTC - Fibre To The Cabinet - uses VDSL modulation as opposed to 'traditional' ADSL broadband.
This forum board is for ADSL (full copper) issues. Fibre broadband has its own board.
If your service is fibre, then please use the POST OPTIONS drop-down, report to moderators and ask them to move this topic to the right board. There people with more FTTC knowledge might have more relevant input. With FTTC an exchange line card is less likely to be an issue for the described symptoms than if this were an ADSL service (where such faults are far more prevalent).
11-07-2020 12:10 PM
Again I don’t understand stand what your saying.
“This forum board is for ADSL (full copper) issues. Fibre broadband has its own board.”
I’ve already explained that they seemed to have found a fault in a 200 pair cable .
There is “copper” going from the house asdl to a fibre cabinet some 350 meters away. There are various joints on the way but tests have proved that there is an issue with a 200 pair COPPER cable which is under the pavement. The ideal solution of course would be to pull in a new multicore COPPER cable but unfortunately there is a blockage in the duct so pulling a cable in is not an easy option as it involves civil works. The engineer found a pair ( the only one left) to get us back up and running. I have no doubt that BT will eventually renew the COPPER when this Covid is all over. I’m pleased they have found the fault and it correlates with research I have done.
I hope that explains the position a little better.
Roger
11-07-2020 12:18 PM
@Gw3xjc The fact that your connection to the cabinet is copper does not alter the fact that you are on a Fibre To The Cabinet service, which means your topic should be on that board.
