Router drop out
greencrofter
Router drop out
This last weekend has been a washout re  Broadband
Friday tested a slow connection and came up with .5MS . In desperation uprooted router and connected to BT master socket
System booted and behold 3-4MS , the fastest it has ever been ( exchange issues but don't get me started ).
Next day ( Saturday)  no connectivity for a long long time ( hours at a time ). The same for  Sunday . So its back to the original connection  now +1MS
Question is ~  why  would the router drop out  when connected to the master socket.  Have tried different filters and used both  Ethernet and wireless
For what its worth  router data below
Anybody any ideas Huh?
Link Information
Uptime: 0 days, 0:19:40
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,184 / 3,200
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,136
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 27.74
Output Power (Up/Down) [dBm]: 12.5 / 18.5
Line Attenuation (Up/Down) [dB]: 28.5 / 46.5
SN Margin (Up/Down) [dB]: 28.0 / 16.0
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 557
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
1 REPLY
Fixes: 68
Re: Router drop out
I'm unable to see an exact reason for the issue but it looks like a fault is at play.
Did anything change on Friday by the way as it looks like your connection was stable for quite a while prior to that:
<img src="http://community.plus.net/visualradius/generated/image1380546645844.png"/>
Either way I'd advise heading to our <a href="http://faults.plus.net//">online fault checker</a> ASAP to get that reported.
 Adam Walker
