Router disconnects about once a day
- Router disconnects about once a day
05-04-2013 3:32 PM
For quite a while now I have suffered apparently random disconnects on average about once a day - if you look at the BQM in my signature you will see there have been two over the last 24 hours. The underlying modem connection is rock solid and has been for about a month now, so I don't know what is causing it. Is it likely to be a router fault? I have the ZyXEL but could swap it for a Netgear. I really don't want to do anything to upset my connection as, when it is connected, it is nice and fast and stable, better than it has been for many months.
Re: Router disconnects about once a day
05-04-2013 3:59 PM
Personally I'd want to keep an eye on things at this stage but wouldn't be too concerned as I can see prior to the last 48 hours you've had much longer connections in excess of 3 days at a time.
Let me know if you see anything more significant.
Adam
05-04-2013 4:09 PM
08-04-2013 10:26 AM
08-04-2013 10:35 AM
08-04-2013 12:16 PM
08-04-2013 4:28 PM
Quote Was that anything to do with your producing the graph?
No, there's no way that could cause that to happen, the two things are totally unrelated.
Quote Why is it doing this? Is it worth trying the Netgear router?
As mentioned it's not really possible for us to diagnose issues of such a low level of disconnections as it shouldn't be having any negative impact on your experience of the service. A connection such as yours can and probably will drop occasionally and the service isn't guaranteed as constant connectivity I'm afraid.
However, if this does concern you trying an alternate router would be a good place to start.
Adam
17-04-2013 2:43 PM
17-04-2013 3:06 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13662075462983.png"/>
Not sure what might have caused that though 😕
17-04-2013 4:22 PM
17-04-2013 5:14 PM
17-04-2013 5:31 PM
18-04-2013 9:28 AM
