Router constantly resetting - Could it be my line?
- Router constantly resetting - Could it be my line?
11-02-2014 11:12 AM
Re: Router constantly resetting - Could it be my line?
11-02-2014 11:19 AM
Our logs definitely reflect the disconnections you've noticed:
<img src="http://community.plus.net/visualradius/generated/image13921174477191.png"/>
I'd advise trying another router if you can just to get that ruled out and then raising a fault if there's still an issue: http://faults.plus.net
11-02-2014 11:23 AM
11-02-2014 11:29 AM
Is this also why my speed has dropped because of the disconnections?
11-02-2014 11:39 AM
If you're noticing the router reset when the connection drops that would usually indicate a router problem so definitely a good idea to rule that out first.
11-02-2014 12:48 PM
12-02-2014 8:51 AM
12-02-2014 9:06 AM
If they won't work both together at the same time, it might be worth trying an alternative router.
12-02-2014 5:28 PM
Not sure if either are related to your problem but sometimes the router/modem just seems to run out of steam.
13-02-2014 11:26 AM
This problem has been solved. Can I see my graph again? there should be no disconnections as of last night (12/02/2014)
Roll on fiber in 2 weeks time.
13-02-2014 6:46 PM
I've never seen a router die so fast
14-02-2014 9:13 AM
<img src="http://community.plus.net/visualradius/generated/image1392369201436.png"/>
14-02-2014 9:20 AM
