Router connects again after manual disconnect
- Re: Router connects again after manual disconnect
21-02-2014 4:24 PM
Hi all
On the homepage of the router (TG582n), I clicked on 'Disconnect' which worked fine, After about 10-15 mins, I noticed I was re-connected again. Is there a way for the router not to connect unless I do it myself ?
Thanks in advance.
Thanks in advance.
Message 1 of 6
(1,145 Views)
5 REPLIES 5
21-02-2014 5:29 PM
Hi Cagney1994,
This shouldn't happen. If you click 'Disconnect' the router should stay disconnected. It may have just been a one-off. If it continues to happen let us know and we can investigate this further.
Message 2 of 6
(761 Views)
21-02-2014 8:38 PM
Thanks Linn. Will you let know if the problem re-occurs.
Message 3 of 6
(761 Views)
14-03-2014 2:41 PM
Hi guys.
Sorry to bump up this thread but going back what I mentioned in the OP; it seems all one has to do to reconnect, is to switch off the router and then back on again. Can anyone confirm if this is a normal action for the router in question ?
Message 4 of 6
(761 Views)
14-03-2014 5:28 PM
Hi Cagney1994,
As far as we're aware if you've clicked "disconnect" and then turned the router off it shouldn't try to re-connect when you turn it back on again. Does this happen every time that you do this?
Message 5 of 6
(761 Views)
15-03-2014 10:58 AM
Hi Linn
Unfortunately the answer's yes
Message 6 of 6
(761 Views)
