Router becomes inaccessible
- Router becomes inaccessible
14-07-2013 12:15 AM
Hi
Just joined PN.- sorry if this has been covered elsewhere I had a look but nothing [guess everyone says that though !] - but if it has please can someone link it ?
Home network as it was for years - only the router has been changed, initially all seemed OK, but ....
Since using PN Technicolour router I am experiencing intermittent problems were no device can connect to the network and those already connected stop working
- this is both ethernet and wifi [pcs and phones]
An ethernet connected pc cannot ping or connect to the router - so I cant see what is happening
Router has been replaced - same problem
All lights show green
Laptop - wifi - shows waiting for IP address ..seemingly looping
Only solution is to recycle the router - then all is well
Seems unplugging or plugging a powerline adapter may cause the issue , but also when the powerline attached device has been working for some time, so not 100% sure of the cause. As each failure requires a recycle I am also concerned about the line getting improperly assessed and the speed decreasing, but will deal with that when issue is resolved
I am going to try an old router - just to ensure the powerline kit is still good , but in the mean time thought Iwould throw out the question, other wise I probably have a new white paperweight
Any ideas ? Or at least how I can get attached to get some diagnostics
Message 1 of 2
(752 Views)
1 REPLY 1
Re: Router becomes inaccessible
14-07-2013 9:08 AM
Is this thread of any help http://community.plus.net/forum/index.php/topic,116315.0.html
Message 2 of 2
(304 Views)
