Router apparently connected but no internet
- Router apparently connected but no internet
17-07-2014 11:02 PM
From time to time (bit too often) I'll be browsing away and internet activity just stops. Look at router, all lights on. The network icon in the tray will sometimes show a triangle but not usually but if it does then I know I'm in for a longer wait. Sometimes it'll reconnect and work OK fairly quickly again other times it takes a router restart (or more patience perhaps). PC is connected by ethernet.
What goes on in these situations?
Message 1 of 7
(1,214 Views)
6 REPLIES 6
Re: Router apparently connected but no internet
17-07-2014 11:26 PM
Just to add to the previous - these events occur at these times from the events log
Recorded Events
Time Message
Info Jul 17 23:22:01 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Jul 17 23:11:51 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Info Jul 17 23:11:34 CONFIGURATION saved by TR69
Info Jul 17 23:11:19 FIREWALL event (1 of 1): deleted rules
Warning Jul 17 23:11:19 PPP link up (Internet) [<snip>]
Info Jul 17 23:11:16 PPP CHAP Chap receive success : authentication ok
Info Jul 17 23:11:08 PPP CHAP Receive challenge (rhost = JUNOS)
Info Jul 17 23:11:05 PPP CHAP Receive challenge (rhost = bras-red7.l-wat)
Info Jul 17 23:11:00 FIREWALL event (1 of 16): modified rules
Info Jul 17 23:11:00 FIREWALL event (1 of 26): created rules
Warning Jul 17 23:10:59 PPP link down (Internet) [snip]
Info Jul 17 23:10:47 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
jim:green IP addresses removed mod:end
Recorded Events
Time Message
Message 2 of 7
(593 Views)
18-07-2014 12:29 PM
This is happening because your line appears to be dropping out a little:
<img src="http://community.plus.net/visualradius/generated/image14056827403209.png"/>
From what I can see, the line is erroring throughout the day, this spikes at some point which is causing your connection to drop. To try and resolve the issue, I'd first try swapping the microfilter over for an alternative. If the problem persists, it's important to remove any extension cabling and connect your router directly to the socket. If at this point it's still an issue, I'd connect directly into the Test Socket.
Message 3 of 7
(593 Views)
18-07-2014 1:02 PM
I can't swap micro-filters as Openreach very recently fitted me with a complete new (I believe it is called) VDSL2 socket. Sticks out far more than the old one (see pic attached).
There's a wired in extension and a plug in one as you see.
Message 4 of 7
(593 Views)
18-07-2014 2:42 PM
Thanks for the image.
If you remove the two screws from the front of the faceplate, there should be a Test Socket, you should be able to connect a Microfilter into that.
Message 5 of 7
(593 Views)
18-07-2014 3:02 PM
@ materialman you might want to follow this guide http://www.coolwebhome.co.uk/faceplate/ I don't believe you can use the test socket on the MK2 simply by removing the front panel as you could with the standard Master sockets
Message 6 of 7
(593 Views)
18-07-2014 5:33 PM
Quote from: Terranova667 I don't believe you can use the test socket on the MK2 simply by removing the front panel as you could with the standard Master sockets
Thank you. I will have a go at this soon. Socket is tucked away in the corner and it's too hot (the weather I mean not the socket.). I might not have realised about the interstitial plate was also the filter.
Message 7 of 7
(593 Views)
