Router Won't connect to broadband
- Router Won't connect to broadband
02-12-2017 10:16 AM
Hi.
I have the Hub One router.
Last night I had a power outage which casued my router to turn off. Once the power came back on the normal lights flashed up but instead of the router going blue it stayed amber with the 'b' on the bottom right.
I accessed the hub, advanced settings and the connectivity is 'disconnected' I re-entred my username and password but it refreshes to the same page with 'Disconnected'.
Any ideas?
Thanks!
Any ideas?
Thanks!
Message 1 of 3
(529 Views)
2 REPLIES 2
Re: Router Won't connect to broadband
02-12-2017 3:59 PM
This is a repeat posting that will probably be deleted by the Moderator. See your other posting for my reply.
Message 2 of 3
(498 Views)
02-12-2017 4:04 PM
Moderator's Note
Topic locked in favour of https://community.plus.net/t5/Broadband/Router-Won-t-connect-to-broadband/m-p/1496241#M319626
Message 3 of 3
(488 Views)
