Router Weirdness!
behaviourneeds
Router Weirdness!
Hi.
The internet light which should be solid green (shouldn't it) however its currently solid red which means that the internet isn't available and yet it is!  I am currently connect and writing this forum post, listening to the internet radio, downloading a load of files and deleting stuff from our amazon account - so its being canned at the minute,
Is this just a quirk and it will go back to normal - I wouldn't mind but the red light makes me think I am going to lose everything at any moment!
My stats are
Uptime: 19 days, 15:08:15
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1.191 / 24.382
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,01
Output Power (Up/Down) [dBm]: 10,3 / 0,0
Line Attenuation (Up/Down) [dB]: 3,6 / 4,5
SN Margin (Up/Down) [dB]: 6,3 / 6,3
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1.450 / 2
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 1.037 / 7.523
HEC Errors (Up/Down): 1.155 / 198.086
Cheers
Chris
Re: Router Weirdness!
Hi Chris,
Your connection looks fine, we've seen a few instances where the inter light is red and the connection remain active.
It's nothing to worry about and I'd suggest if this does bother you doing a simple disconnect then connect via your routers interface and it should go back to green.
behaviourneeds
Hi Chris,
Yep - disconnecting and reconnecting has cleared the red light!
Thanks very much
Chris
