Router Suggestions - Fibre Line
- Re: Router Suggestions - Fibre Line
18-07-2013 10:36 PM
The Technicolor TG582n seems to be a good bit of kit if all you want to do is browse the web and don't care about anything other plugging it in and leaving it.
I usually avoid ISP provided kit due to the woefully inadequate "simple" interfaces and generally poor performance. Not to mention the pushed firmware updates that scrub settings and reset everything to the vendor defaults. Thus re-enabling unsafe functions I'd turned off because I know better (uPNP anyone)?
Since its using my electric bill and Plusnet seem intent on inflicting its will on my settings - its time to replace this cheesy, slow, white box of woe, with a more capable bit of kit.
Can I just grab any "Cable" enabled router with a WAN port since the Openreach box outputs Ethernet?
If there is a compatible routers list for Fibre enabled connections that I've missed, please do point me at it.
Much Appreciated
D
Much Appreciated
D
Message 1 of 7
(1,324 Views)
6 REPLIES 6
18-07-2013 10:43 PM
Pretty much anything with Ethernet WAN and PPPoE connection setting will work, just choose the one with the features / quality & performance that suits you best, you can probably find something anywhere from about £15 or £20 to well over £200.
There are a few with built-in VDSL2 modems that will also replace the BT Openreach modem.
Call me 'w23'
Message 2 of 7
(531 Views)
18-07-2013 10:52 PM
here is a big list of compatible ones at broadbandbuyer
Message 3 of 7
(531 Views)
18-07-2013 11:04 PM
Quote from: DarK Can I just grab any "Cable" enabled router with a WAN port since the Openreach box outputs Ethernet?
Bear in mind that Plusnet have insanely long PPP timeouts which mean that if you disconnect your old router from the modem without doing a clean disconnect from the router web interface it will take between 6 and 8 minutes before you will be allowed to connect again - you have to wait until the stale PPP session is killed off by Plusnet's servers.
Message 4 of 7
(531 Views)
19-07-2013 7:50 PM
With a bit of extra reading its looking like I will go with a ZyXEL with an in-built VDSL Modem to get rid of the Openreach box as well, which will free up some power sockets.
Thanks all
D
Thanks all
D
Message 5 of 7
(531 Views)
19-07-2013 9:55 PM
Quote if you disconnect your old router from the modem without doing a clean disconnect from the router web interface it will take between 6 and 8 minutes before you will be allowed to connect again - you have to wait until the stale PPP session is killed off by Plusnet's servers.
Well I never have that problem using my Asus RT-N56U. I agree, my old PN supplied router used to take an eternity but it's a rubbish router so I expected nothing else.
Message 6 of 7
(531 Views)
20-07-2013 7:12 AM
Some routers can do a "dying gasp" release of the PPP connection - when they detect power is going they bang out the PADT frame to end the PPP session. Your ASUS might do that. Or it might fake a PADT before trying to bring up the connection (that's what I do on my homebuilt router). It is also possible you just didn't see it because it took you more than 6-8 minutes to swap your routers over and get them configured onto the line.
This is a configuration issue with Plusnet's servers and anything which goes away without sending a PADT first will leave you with a fibre connection which is unusable for 6-8 minutes.
Message 7 of 7
(531 Views)
