Router Stats
chrish16
Router Stats
Hi
Can you check my stats please and let me know what you think?
System Up Time 57:00:22
Port                     Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN            PPPoA 718875 926294              0 1040 4812 56:59:11
LAN              10M/100M 74699 880                      0 36              0 57:00:16
WLAN 11M/54M/270M 1002833 792506 0 4948 1121 57:00:06
ADSL Link Downstream Upstream
Connection Speed 8139 kbps 1063 kbps
Line Attenuation           45.5 db 24.1 db
Noise Margin             4.3 db 5.6 db
Does that first bit tell me if i have any data send/receive errors?
Also sinc emy upload uncap it shot up to 1063kbps from 448kbps  There is in fact a little bit more i could get out of it but unsure how to tweak my SNR on just upload, i can't really drop the single control i have in my router because on an evening the down SNR drops to about 3db.  I'm in my training period still, got connected on Monday 10th
jojopillo
Re: Router Stats
Hi chrish16,
Personally I think you've got very good stats for your line length. Be careful tweaking, you could make things worse. I don't think a few extra K is likely to make much difference to your experience.
Jojo Smiley
Fixes: 10
Re: Router Stats
We've already answer this question:
Quote from: Joanne
Hi chrish16,
As Matt said, you're definitely on ADSL2+. With your attenuation registering at 45.5dB the current speed you're getting is above average I would say.
Jojo Smiley
Quote from: jelv
http://www.kitz.co.uk/adsl/max_speed_calc.php
Predicted sync for your attenuation is 7200!
Why have you started a new topic?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
chrish16
Re: Router Stats
I never posted my stats before thats why.
Fixes: 62
Re: Router Stats
jim:post
Post removed - stop piling in against a relatively new poster mod:end
