Router Stats since ADSL2
- Router Stats since ADSL2
- « Previous
- 1
- 2
- Next »
Re: Router Stats since ADSL2
06-06-2012 1:39 PM
Hi mojorisin,
Your line seems to have improved over the last couple of days. Have you made any changes?
Jojo
Jojo
Message 16 of 19
(195 Views)
06-06-2012 11:53 PM
Hi JoJo
I haven't changed anything other than replacing the router as mentioned but on checking the stats again it still seems to be fluctuating quite a bit on the noise levels
ADSL Link Downstream Upstream
Connection Speed 2860 kbps 444 kbps
Line Attenuation 60.5 db 35.4 db
Noise Margin 3.0 db 17.7 db
Message 17 of 19
(195 Views)
07-06-2012 1:11 PM
Well, the way things are at the moment it's looking rather stable.
Message 18 of 19
(195 Views)
07-06-2012 6:13 PM
Very interested in your situation! I too have a Linksys WAG200G with crazy SNR values.
I also bought a new modem router but that had the same problems (if not worse) so I am now back to the Linksys.
You might find running routerstats lite to be usefull.
http://www.vwlowen.co.uk/internet/files.htm#routerstatslite
It is a free windows utility which logs SNR, connection speed and can also log ping response times.
You get nice graphs and it can also write results to a text logfile for further analysis.
Message 19 of 19
(195 Views)
- « Previous
- 1
- 2
- Next »
