Router Question
catherinet556
Router Question
I was just wondering about the BT Home Hub 3, and if it works with plusnet without the need for hacking?
As around the web all i come across is "How To Hack" type websites.
Replies Much Appreciated.  Roll eyes
mushy
Re: Router Question
Yes the BT Home Hub 3 works on plusnet, log into the router and use your plusnet username (username@plusdsl.net) and password
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Fixes: 64
Re: Router Question
No hack should be needed as @mushy mentions.
If you're not sure how to change the login details you should be able to find a guide here:
http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-for-bt-broadband-hardware
 Adam Walker
catherinet556
Re: Router Question
thank you for the help, much appreciated!
i have figured out how to Do it, now i have to wait for broadband to be activated!  Roll eyes
