Router Question
- Re: Router Question
Router Question
10-02-2013 5:50 PM
I was just wondering about the BT Home Hub 3, and if it works with plusnet without the need for hacking?
As around the web all i come across is "How To Hack" type websites.
Replies Much Appreciated.
Message 1 of 4
(936 Views)
3 REPLIES 3
Re: Router Question
10-02-2013 10:24 PM
Yes the BT Home Hub 3 works on plusnet, log into the router and use your plusnet username (username@plusdsl.net) and password
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml
Message 2 of 4
(371 Views)
Re: Router Question
11-02-2013 11:41 AM
No hack should be needed as @mushy mentions.
If you're not sure how to change the login details you should be able to find a guide here:
http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-for-bt-broadband-hardware
Message 3 of 4
(371 Views)
Re: Router Question
13-02-2013 6:25 PM
thank you for the help, much appreciated!
i have figured out how to Do it, now i have to wait for broadband to be activated!
Message 4 of 4
(371 Views)
