Router Password / Username
- Router Password / Username
20-03-2012 9:05 PM
Hi, I was wondering whether anyone could help me or not. I want to change the password on my router and have tried to follow the Plusnet guide on this. It states that, unless I have installed a password, I should be able to access my router by putting my IP address into my browser.
I've done this but am being asked for a username and password. The problem I'm having is that I've never set up a username or password and I've tried every combination of the codes on the back of the router but none are correct! I've even tried them in combination with Administrator as the username but still no joy!
Can anyone offer any advice as to how I can rectify this? I've tried looking for the manual that came with it but can't find it!
Message 1 of 5
(1,271 Views)
4 REPLIES 4
Re: Router Password / Username
20-03-2012 9:07 PM
Try these
Message 2 of 5
(768 Views)
20-03-2012 9:23 PM
Thanks but none of those work either!
Message 3 of 5
(768 Views)
20-03-2012 9:25 PM
It just occurs to me - you shouldn't be putting your IP address in
If it is a Thomson Router (as supplied by Plusnet) put this in your browser window http://192.168.1.254
Message 4 of 5
(768 Views)
20-03-2012 9:44 PM
as jim says on web page you should see this Password is on router generally starts CP and is CASE sensitive
Message 5 of 5
(768 Views)
