Router Login and Password Recovery?
- Re: Router Login and Password Recovery?
17-08-2008 6:57 PM
Is there anyway I can recover my router login or password as I can't remember the details I entered when I first joined.
I want to use the DMT.exe program which I use to tweak my settings but uninstalled it when getting rid of a lot of programs on my PC.
I've now got the DMT program back again and it prompts you to enter your router login and password.
Message 1 of 4
(1,429 Views)
3 REPLIES 3
17-08-2008 7:01 PM
Sorry
Remove this post
I've just remembered them
Remove this post
Message 2 of 4
(513 Views)
17-08-2008 8:26 PM
Nooo! You've got to tell us all what it is!
For completeness, you understand . . .
Message 3 of 4
(513 Views)
17-08-2008 8:35 PM
Invariably the way out of this problem is to press the reset button at the back of the router to wipe out all its configuration. Then you will need to manually re-enter your login details and can set a new password. Default passwords are either blank, "password", "admin", or provided in the router documentation.
If you are running a netgear and have a backup of its configuration, then open it with a text editor and you should see something like this:
Hope this helps next time.
#< Set Password >
[110001]"Username"=admin
[110002]"Password"=V3ryD1ff1cu7t
# 0 ~ 99
[110003]"Login times out"=5
Message 4 of 4
(513 Views)
