Router Firewall
- Router Firewall
Router Firewall
29-07-2009 1:25 AM
when my xbox 360 is hooked upto the router it works ok but in the "event log" the traffic lights on amber,this means warning,and log displays this message beside it
"FIREWALL rule : Protocol: UDP Src ip: 98.216.34.205 Src port: 3074 Dst ip: 192.168.1.64 Dst port: 3074 Chain: forward_host_service Rule Id: 5 Action: accept"
is this a problem occuring does any one know? im using the thompson TG585 v7.
If life gives you lemons, make lemonade.
Message 1 of 2
(591 Views)
1 REPLY 1
Re: Router Firewall
29-07-2009 6:54 AM
Doubt it's anything to worry about to be honest. Probably just UPnP doing what it's supposed to by forwarding gaming traffic to your xbox.
Message 2 of 2
(219 Views)
