Router Ethernet SetUp
- Router Ethernet SetUp
23-01-2013 7:32 PM
When my original Router didn't work, I swiftly bought a router from PC World - Belkin N150 Surf, while setting this up for wireless was easy
I just don't know how to connect it for ethernet use to fully try my Fibre limits, can anybody either guide me or point me to a tutorial (abc as I have no real prior knowledge for these items)
Just plugging the ethernet cable into the appropriate sockets has no noticeable effect and it's still coupled via wifi
Ethernet Belkin N150 Surf Setup
http://www.expertreviews.co.uk/wireless-routers/1283788/belkin-surf-n150
Message 1 of 6
(1,450 Views)
5 REPLIES 5
Re: Router Ethernet SetUp
23-01-2013 10:26 PM
Turn the WIFI off on your computer/laptop. Windows usually prefers wifi over ethernet for some strange reason
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 6
(731 Views)
24-01-2013 1:37 AM
tried that but just disconnected and the Plusnet Assist popped up and whirred away for a few minutes,
reconnected wireless, will retry the 2nd supplied router and see if I can coax it back to life
Disconnected a few times tonight maybe the router ??
thanks for your reply
Message 3 of 6
(731 Views)
24-01-2013 10:53 AM
Hi.
Plusnet Assist is very good at reconnecting a Wireless connection once it's been set up. In your case, perhaps too good If you temporarily want to stop it reconnecting you (which it sounds like you do want to to test out Ethernet), then you can turn off Plusnet Assist by right-clicking on the sys-tray icon (bottom-right of your screen) and selecting 'Exit'. Turn off your wireless (either at the switch or via Windows) and Plusnet Assist won't trouble you. Connect to Ethernet and away you go.
When you want to get Plusnet Assist going again, simply double-click the icon on your desktop or restart your computer.
Message 4 of 6
(731 Views)
24-01-2013 11:00 AM
There's a lot of us who would recommend uninstalling Plusnet assist. There's nothing that it does that you can't do yourself if you are reasonably competent.
Message 5 of 6
(731 Views)
24-01-2013 7:56 PM
Problem solved - discovered the LAN Gigabit driver wasn't installed d/l same and PC immediately saw the LAN connection
Looks Good
Good D/L speed av transfer speed 9.05MB/sec 4min 17secs to D/L 2.3GB
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (MBps): 69.71
Upload Speed (MBps): 14.71
Ping Latencey (ms): 41.63
Looks Good
Message 6 of 6
(731 Views)
