Router Change And Going Static
- Router Change And Going Static
- « Previous
- 1
- 2
- Next »
Re: Router Change And Going Static
07-04-2014 7:27 PM
Hi Chris,
Right... that's interesting. Not had many problems so far, just two dropouts which is a country mile better than before. I believe they are because I had set-up the router incorrectly to connect to Plusnet (not setting it up to PPPoA) and having the Static IP setup. Thanks for the link, I will happily have a look at it. Many thanks to all the replies :). I don't understand it but now I get a better connection to Minecraft servers, from 200MS to less than 50MS is astonishing.
Message 16 of 17
(193 Views)
07-04-2014 7:38 PM
Thanks Chris, the link solved my Minecraft problem.
Message 17 of 17
(193 Views)
- « Previous
- 1
- 2
- Next »
