Right place? (Fixed)
St3althM4ster
Hi all dont know if this is the right place, but i have routing problems to my server "i think" can anything see if they can connect to lcesrp.com or tracert as mine stop at hop 4 thanks.
St3althM4ster
Re: Right place?
C:\Users\Ashley>tracert lcesrp.com
Tracing route to lcesrp.com [176.31.14.24]
over a maximum of 30 hops:
  1    3 ms    1 ms    1 ms  10.0.0.1
  2    14 ms    14 ms    15 ms  lo0-central10.ptn-ag02.plus.net [195.166.128.191
  3    16 ms    15 ms    15 ms  link-b-central10.ptn-gw02.plus.net [212.159.2.13
4]
  4    16 ms    18 ms    14 ms  hsrp.pth-gw1-2.plus.net [212.159.1.62]
  5    *        *        *    Request timed out.
  6    *        *        *    Request timed out.
  7    *        *        *    Request timed out.
  8    *        *        *    Request timed out.
  9    *        *        *    Request timed out.
10    *        *        *    Request timed out.
11    *        *        *    Request timed out.
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *        *        *    Request timed out.
15    *        *        *    Request timed out.
16    *        *        *    Request timed out.
17    *        *        *    Request timed out.
18    *        *        *    Request timed out.
19    *        *        *    Request timed out.
20    *        *        *    Request timed out.
21    *        *        *    Request timed out.
22    *        *        *    Request timed out.
23    *        *        *    Request timed out.
24    *        *        *    Request timed out.
25    *        *        *    Request timed out.
26    *        *        *    Request timed out.
27    *        *        *    Request timed out.
28    *        *        *    Request timed out.
29    *        *        *    Request timed out.
30    *        *        *    Request timed out.
Trace complete.
hex
Re: Right place?
Does not look like the hostname resolves on the Plusnet DNS servers at the moment which I imagine is causing the traceroute to fail - did you create/update it recently?  (can take a while for changes to propagate - would give it a try in another day or two if this is the case)
Fixes: 71
Re: Right place?
The DNS I use (which is not PN) also doesn't resolve lcesrp.com. Reverse DNS for 176.31.14.24 shows vps176.31.14.24.weblayer.co.uk and this does not respond to pings.
David
St3althM4ster
Re: Right place?
Ive not touched nothing for 10days or more, and all of sudden it goes today people on bt. pn, vm all got cut off at same time on team speak, but it seems to be up now, apprently to host ip came locked. what ever that means
Fixes: 71
Re: Right place? (Fixed)
Yes, tracert works now:
C:\>tracert lcesrp.com
  1    36 ms    98 ms    99 ms  192.168.1.254
  2    24 ms    25 ms    25 ms  lo0-central10.pcl-ag07.plus.net [195.166.128.188]
  3    25 ms    25 ms    25 ms  link-b-central10.pcl-gw02.plus.net [212.159.2.186]
  4    25 ms    24 ms    24 ms  218.core.access.plus.net [212.159.0.218]
  5    76 ms    25 ms    24 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  7    29 ms    30 ms    28 ms  rbx-g1-a9.fr.eu [91.121.215.141]
  8    28 ms    *      54 ms  vss-1b-6k.fr.eu [91.121.131.82]
  9    28 ms    29 ms    29 ms  vpsnode01.weblayer.co.uk [94.23.12.10]
10    29 ms    29 ms    27 ms  vps176.31.14.24.weblayer.co.uk [176.31.14.24]
Trace complete.
David
