Ridiculous wireless speeds
- Ridiculous wireless speeds
29-05-2014 2:06 PM
With a wired connection I get 66 DL and 11 UL
With wirless it drops significantly to 5-11 DL and 1-3 UL. (5M away from the router).
If I go near the router, (literally ontop of it) I get 24 DL and 11 UL.
It's either the router has terrible wireless or my computer doesn't have a very good network adapter card. Testing other computers as I write..
Message 1 of 6
(1,015 Views)
5 REPLIES 5
Re: Ridiculous wireless speeds
29-05-2014 2:24 PM
Tested 2 more laptops (HP & Acer) and they both recieved 14-19 DL and 11UL near the router. Is the router supplied THAT bad? Honestly!
Message 2 of 6
(633 Views)
29-05-2014 2:35 PM
To me that is a very good connection.
Wireless is a shared medium. Lots of things share the spectrum and have to transmit and receive on the same 'pipe.'
Have you tried switching channels on the router ?
If you have a smartphone, download wifi analyser and see which channels are in use. Try to pick a channel with the least congestion and test again, but, stick with either channel 1, 6 or 11
Message 3 of 6
(633 Views)
29-05-2014 2:38 PM
Losing 50 mb/s download speed is not what I would call 'good'. Anyway; it could be because of the freezer that is situated >0.5 m away from the router (until we can find a good place to put it).
I'll try that wifi analyser, thanks.
dick:quote
dick:quote
Message 4 of 6
(633 Views)
29-05-2014 2:59 PM
the freezer is most likely causing some interference - whether it is 50Mbps worth of interference is another matter.
a whole manner of things can cause WIFIinterference - cordless phones, cordless doorbells, automatic garage doors, microwaves... no name just a few.
and those items don't even need to be in your home for them to cause interference... next doors doorbell is enough.
this is the major flaw with WIFI in general.
of course, even with N WIFI, you will never get anywhere near the advertised speed as that is optimum and only achievable in labs.
Message 5 of 6
(633 Views)
29-05-2014 3:03 PM
I get around 20-30Mb through wireless - it was around 3-4 before I changed the channel to one a bit less congested.
Message 6 of 6
(633 Views)
