Ridiculous upload speed
- Ridiculous upload speed
19-07-2013 4:59 PM
Here are the DSL Connection details
Quote Link Information
Uptime: 0 days, 6:05:55
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 20,060 / 12,000
Bandwidth (Up/Down) [kbps/kbps]: 994 / 11,286
Data Transferred (Sent/Received) [MB/GB]: 378.35 / 7.31
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 23.5 / 39.0
SN Margin (Up/Down) [dB]: 5.5 / 3.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 2,949,084 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2,949,133 / 0
FEC Errors (Up/Down): 3,100 / 5,932,277
CRC Errors (Up/Down): 64,341 / 3,293
HEC Errors (Up/Down): 209 / 123,724
And here is the speed test from speedtest.net - http://www.speedtest.net/my-result/2847033963
please help me fix my net !
Re: Ridiculous upload speed
19-07-2013 5:01 PM
Doesn't look like there's anything wrong there? That's a pretty good upload speed for uncapped ADSL2+. What did it used to be please?
19-07-2013 5:06 PM
Edit - So games are unresponsive when played online, youtube and netflix seem to be fine, skype is fine, downloading from dropbox is fine but the upload takes triple the time it should. im so baffled by what is going on, no body seems to know
19-07-2013 5:49 PM
Also for only 6 hours running the download errors are also high but I don't think that is the problem
19-07-2013 5:58 PM
19-07-2013 6:14 PM
Noise Margin: 10.0 dB
Bandwidth: 832 kbps
Attenuation: 27.0 dB
Errors: CRC: 240
19-07-2013 6:15 PM
19-07-2013 6:51 PM
If you dial 17070 option 2 is the line completely quiet - preferably with a corded phone
Assuming that this is quiet the next thing is to try the test socket and check the errors after a few hours
Which router do you have
19-07-2013 6:57 PM
Quote Product Name: TG585 v8
Software Release: 8.2.7.7
19-07-2013 7:08 PM
I don't know if the user defined part works but if it does can you set it to graph the upstream crc's
19-07-2013 7:35 PM
19-07-2013 8:38 PM
From the main screen select Summary
Then using the mouse select the CRC upstream like the picture (you do it by dragging the mouse over it with the left button depressed just like selecting text in a document and right click to get the menu and click on user def it will then graph it.
You can do the same thing with downstream CRC if you wish
20-07-2013 1:05 PM
20-07-2013 4:57 PM
have you tried the test socket to see if the errors are about the same
20-07-2013 8:45 PM
