Revert to capped upstream
- Revert to capped upstream
10-01-2013 1:20 PM
Uncapping my upstream hasn't really worked for my line, upstream is slower than before as is downstream. Line is stable though, no resyncs except when I unplugged the router to get rid of a mains extension block. Can a PlusNet agent arrange for my upstream to be capped again please? I guess my speeds are as good as they are going to get given the length of line.
HughA
HughA
Message 1 of 7
(1,312 Views)
6 REPLIES 6
Re: Revert to capped upstream
10-01-2013 1:44 PM
It's a shame it didn't help, sometimes that's the case though. I've placed a modify order to cap your upstream and it'll complete tomorrow.
Message 2 of 7
(643 Views)
10-01-2013 4:38 PM
Hi Chris
Had a resync at 15:20 this afternoon, I guess as a result of your modify order. Unfortunately the upstream is now only 128Kbps whereas downstream is now 3072Kbps. This must indicate a line issue surely? Just realised this return of poor upstream sync has once again arrived with the cold weather - there is a definite correlation.
HughA
HughA
Message 3 of 7
(643 Views)
10-01-2013 5:29 PM
The modify order hasn't completed and won't until tomorrow, I'd suggest disconnecting your connection and via your routers interface and then after a few minutes reboot your router and connect back up.
See if there is any difference and keep me updated.
Message 4 of 7
(643 Views)
10-01-2013 6:21 PM
Rebooted router and now have 416Kbps upstream, 2912Kbps downstream.
Message 5 of 7
(643 Views)
11-01-2013 11:40 AM
That now seems to have taken effect, it looks like your downstream has increased since too.
Message 6 of 7
(643 Views)
11-01-2013 11:42 AM
Upstream now restored to 448Kbps and downstream 3392Kbps. If it stays like this I shall be very happy, I can live with the capped upstream and downstream is better than I've had for a long time!
Thanks for your help.
HughA
HughA
Message 7 of 7
(643 Views)
