Reverse DNS lookup on Static IP saga .....
Apprentice
http://community.plus.net/forum/index.php/topic,111654.16.html
Following on from comments made in the above thread can I get an adjustment on my static IP so as the hostname doesn't show up as my username i.e. "myusername".plus.com
This didn't occur before when I had a static IP with madasafish.
Fixes: 162
Re: Reverse DNS lookup on Static IP saga .....
I'll sort it to ip_address.plus.com - it'll take several hours to change though.
 Chris Parr
 Plusnet Staff
Apprentice
That's great Chris thanks a lot, the time taken to complete isn't a problem. Smiley
Apprentice
Update
The hostname does now appear as the ip_address.plus.com
Thanks again
