Reverse DNS look for my static IP
sukeshn
I've just realised that the reverse DNS lookup for my static IP (lookup of my IP Address in DNS) reveals my plusnet username! It is basically <myusername>.plus.net
This is unacceptable! I dont want my username revealed to would be hackers, it is a security risk
How do I get this removed or at least changed?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Reverse DNS look for my static IP
Hi sukeshn,
I can change it so that it has your IP address if you'd prefer?
Chris Pettitt
Cloud Environments Engineer
sukeshn
Yes that would be ideal.
Plusnet Staff
Plusnet Staff
Fixes: 5
No problem. I've submitted that for you, that should take effect within the next 4 hours.
Chris Pettitt
