Reverse DNS look for my static IP
- Re: Reverse DNS look for my static IP
15-11-2013 1:34 PM
I've just realised that the reverse DNS lookup for my static IP (lookup of my IP Address in DNS) reveals my plusnet username! It is basically <myusername>.plus.net
This is unacceptable! I dont want my username revealed to would be hackers, it is a security risk
How do I get this removed or at least changed?
Message 1 of 4
(871 Views)
3 REPLIES 3
15-11-2013 1:41 PM
Hi sukeshn,
I can change it so that it has your IP address if you'd prefer?
Message 2 of 4
(480 Views)
15-11-2013 2:02 PM
Yes that would be ideal.
Message 3 of 4
(480 Views)
15-11-2013 2:06 PM
No problem. I've submitted that for you, that should take effect within the next 4 hours.
Message 4 of 4
(480 Views)
