Returning customer
- Returning customer
Returning customer
28-05-2014 4:33 PM
Suppose to have my Broadband service connected tomorrow.Does BT contact me on the same day or does Plusnet call me ?
Message 1 of 7
(935 Views)
6 REPLIES 6
Re: Returning customer
28-05-2014 4:59 PM
Welcome back, I've checked your order and the install isn't due until 30th May 8am - 1pm I'm afraid, I know you have been told different prior to this so apologies.
It is going ahead for that date and the engineer will get your fibre active for you.
To add..... we won't call you on the day, once the engineer has done the install you will be online.
Message 2 of 7
(547 Views)
28-05-2014 5:57 PM
I've got to go to the Diabetic clinic 11:30 Friday.Could you change the time to 14:00 (2pm) on that day ?Finally why do you keep changing the date ?
Message 3 of 7
(547 Views)
29-05-2014 9:07 AM
The engineer will not need access to your premises as it is a migration, the engineer will complete the work externally and then you should be online.
The date hasn't changed, your were advised the wrong date in the first place unfortunately.
Message 4 of 7
(547 Views)
29-05-2014 12:30 PM
My present ISP put a white box below the router,can I unplug that as well ?
Message 5 of 7
(547 Views)
29-05-2014 12:40 PM
Does it say 'Openreach' on it? Sounds like that's your fibre modem, the router will need to be plugged in to that.
Message 6 of 7
(547 Views)
29-05-2014 1:13 PM
It does.Thanks,will just unplug router.
Message 7 of 7
(547 Views)
