Retaining speed data from the Speedtester
- Retaining speed data from the Speedtester
06-05-2008 11:24 AM
When the Plusnet speedtester became available, it would hold previous test data so that I could compare speeds over a period. It no longer seems to do this, although posts on the forum suggest that it can be done. A question to Plusnet was answered by a message that said I had to have cookies allowed in some way, but refused to give me the method, referring me to the Forums. So jere is the question; What do i have to do to enable the speedtester to retain a history of results?
Anyone know the answer?
Message 1 of 3
(1,003 Views)
2 REPLIES 2
Re: Retaining speed data from the Speedtester
06-05-2008 11:28 AM
In Opera : Tools > Preferences > Avanced > Cookies. Then select your preference.
In Firefox : Tools > Options > Privacy. Then tick the cookies box and set the expiry if required.
What browser do you use?
Message 2 of 3
(421 Views)
06-05-2008 5:27 PM
Thanks for that, I will give it a try. I use mainly Firefox, but sometimes IE7
Message 3 of 3
(421 Views)
