Restricting access to internet by time
- Restricting access to internet by time
25-07-2018 11:55 AM
Re: Restricting access to internet by time
25-07-2018 2:11 PM
Hi Gareth, there isn't a setting for that in the Hub One, only the ability you've mentioned to do so between specific times. All I could suggest is for you to set that up at the times you want to allow access. Alternatively you might find a software based solution for this if you do some google searching.
on 25-07-2018 2:16 PM - last edited on 25-07-2018 11:31 PM by Strat
As I supposed - trust me when I say this would be VERY useful for most parents. I dont really want the fuss of setting up separate times on separate days - what I want is a facility that allows freedom - but then has limits.
Ok - not easy - I'll see what our friend Google suggests....
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules.
