Restricting Router - Help please
- Re: Restricting Router - Help please
24-02-2015 10:07 AM
I am having problems through the night with my kids on games consoles etc. Can anyone tell me if it's possible for me to put a restriction on the router so it shuts off between 12am and 7am please?
Thank you
24-02-2015 10:18 AM
I am sorry to have to say this but we don't have anyway of supporting the option you are wanting.
There is software available out there, and I am sure if you keep checking this thread the guys in the forums will offer some advice on other options available to you.
24-02-2015 10:19 AM
24-02-2015 11:47 AM
http://192.168.1.254/wlan_tod.lp?be=0&l0=4&l1=2
A thought - you may need to update the firmware to : 10.2.2.B but as I don't have the earlier one I can't check
24-02-2015 12:50 PM
26-02-2015 4:51 PM
This page will allow you to restrict access time device by device without shutting down WiFI for everyone.
WARNING it is not unheard of smart kids resetting the router back to default setting using a paper clip in the back of the router! See http://community.plus.net/forum/index.php/topic,134934.msg1182490.html#msg1182490
01-03-2015 2:10 AM
With the Dlan 500 wireless access you can set dates, times, special SSID and keep them off the main LAN.
HTH
02-03-2015 10:51 AM
Devolo are indeed excellent units, however it should noted that some home plugs have been known to create interference with ADSL. Personally I have not seen this with Devolo units.
