Restricting Access
- Restricting Access
Restricting Access
29-08-2012 3:37 PM
Hi.
Does anyone know whether it is possible to restrict access at certain times of the day for different devices on my network?
I used to have a BT homehub and it was really easy to just log into the router and do this.
I emailed plusnet for help - but they've told me to come to the forum as they can't help!
Would be really grateful if anyone does know how to do this.
Message 1 of 6
(1,064 Views)
5 REPLIES 5
Re: Restricting Access
29-08-2012 5:27 PM
Hi jolene88,
Can you tell us which modem/router you have at the moment and we can let you know if it's possible!
Message 2 of 6
(501 Views)
29-08-2012 6:09 PM
Hi it's a technicolour TG582n
Message 3 of 6
(501 Views)
29-08-2012 8:07 PM
Hi, I don't think the TG582n has that facility. However if you've still got the HomeHub, most of them will allow you to configure a PlusNet username/password, see here for details http://bt2700hgv.tripod.com/ir1002700HGVplusnethomehub.htm
If yours will then go back to using that if it provides the facilities you need.
Message 4 of 6
(501 Views)
30-08-2012 12:22 PM
Thanks I will give that a go then as I found that the homehub was brilliant for parental controls.
Message 5 of 6
(501 Views)
30-08-2012 12:32 PM
I trust that works OK,
K9 has a facility that will do that,plus certain sites can be blocked.
Problem is that it has to be installed on all PCs,
I have it on my computer as teenage grand children use my PC when they visit.
Message 6 of 6
(501 Views)
