Resetting connection ?
- Re: Resetting connection ?
07-04-2014 8:33 PM
From late December to March 27th I had an excellent and stable connection with the only disconnects being due to power cuts during the winter storms.
Bandwidth was abt 2500 kbps and d/l speeds around 2 Mb/sec - pretty good for my connection.
Then for no obvious reason end March /early April saw a few disconnects with bandwidth dropping to +/-1350 kb/sec and d/l speed abt. 1 Mb.
So, early AM on April 6th I switched off the router for about 30 minutes and saw that the band width reset itself to 2550 kbps - great.
Unfortunately the d/l speed is still around 1 kbps and I'm wondering whether someone could be so kind as to reset this for me, as has happened from time to time in the past.
Message 1 of 4
(498 Views)
3 REPLIES 3
07-04-2014 9:20 PM
I assume that you are on 21CN and if so it only needs the Plusnet current line speed updating https://portal.plus.net/my.html?action=data_transfer_speed but just to confirm can you check the BT IP profile from the BT speed test further diagnostics
Message 2 of 4
(336 Views)
07-04-2014 10:29 PM
Not to worry - it seems to have fixed itself now. I should have waited another day.
Sorry to have wasted your time.
Message 3 of 4
(336 Views)
07-04-2014 10:33 PM
No problem - I wish they were all so easy
Message 4 of 4
(336 Views)
