Resetting SNR
caoli
Resetting SNR
After 10 months of stable , happy broadband, at around 2mb d/l  with a stable SNR (  I live in a very rural location) my BB has dropped dropped off significantly. A quick check reveals a d/l SNR of 22.8 .
How does one go about getting the SNR reset.    I appreciate its a balancing act between stablity and speed, but I've had 10 months of both ( well relative to my location) I'm actaully in telecoms, the line tests fine, no noise, so not sure why its suddenly gone downhill rapidly
Fixes: 54
Re: Resetting SNR
I wouldn't do this at night (when the environment is generally more electronically noisy) but have you tried restarting the router to see if your target noise margin really has increased?
David
Fixes: 24
Re: Resetting SNR
Quote from: caoli
... not sure why its suddenly gone downhill rapidly
It's because the line suffered a large number of losses of sync in a short amount of time.  If you can get to the bottom of why that happened then perhaps you can prevent it happening again.  Any recent electrical work or thunderstorms?
Re: Resetting SNR
Hi caoli,
Not sure what caused your SNR to shoot up, everything on your line has been very stable over the past few days so I've placed a SNR reset on your line improve things for you. This can take upto 4 hours for you to see the desired effect.
