Resetting SNR
- Re: Resetting SNR
Resetting SNR
25-10-2013 8:30 PM
After 10 months of stable , happy broadband, at around 2mb d/l with a stable SNR ( I live in a very rural location) my BB has dropped dropped off significantly. A quick check reveals a d/l SNR of 22.8 .
How does one go about getting the SNR reset. I appreciate its a balancing act between stablity and speed, but I've had 10 months of both ( well relative to my location) I'm actaully in telecoms, the line tests fine, no noise, so not sure why its suddenly gone downhill rapidly
Message 1 of 4
(867 Views)
3 REPLIES 3
Re: Resetting SNR
25-10-2013 11:22 PM
I wouldn't do this at night (when the environment is generally more electronically noisy) but have you tried restarting the router to see if your target noise margin really has increased?
David
Message 2 of 4
(392 Views)
Re: Resetting SNR
26-10-2013 2:17 AM
Quote from: caoli ... not sure why its suddenly gone downhill rapidly
It's because the line suffered a large number of losses of sync in a short amount of time. If you can get to the bottom of why that happened then perhaps you can prevent it happening again. Any recent electrical work or thunderstorms?
Message 3 of 4
(399 Views)
Re: Resetting SNR
28-10-2013 12:02 PM
Hi caoli,
Not sure what caused your SNR to shoot up, everything on your line has been very stable over the past few days so I've placed a SNR reset on your line improve things for you. This can take upto 4 hours for you to see the desired effect.
Message 4 of 4
(399 Views)
