Reset router remotely
pmjames911
Is it possible to reset my router remotely to pick up my new fixed IP as I am away from home?
thanks
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: Reset router remotely
I'm not sure how you would do this yourself however I could perform a session kill for you tomorrow morning and this will drop the PPP session which should reconnect automatically.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
pmjames911
Thanks. That would be great
Plusnet Staff
Plusnet Staff
Fixes: 117
I've submitted a session kill now which should go through within about 5 minutes.
 Plusnet Staff
pmjames911
that worked perfectly. Many thanks
Plusnet Staff
Plusnet Staff
Fixes: 117
Awesomeness, good to hear.
Anything else I can help with just let me know.
 Plusnet Staff
