Reset my Weird SNR
glloyd
Reset my Weird SNR
Can someone kindly rest my SNR to 6db up an down. For some reason they are set 8 down and 10 up which is very odd.
Fixes: 150
Re: Reset my Weird SNR
The SNR target on your line is actually 6db so a reset wouldn't benefit you.
Have you tried a resync?
 Matthew Wheeler
glloyd
Yes I have it's still 8db down 10db up even your checks say the same thing
Plusnet Staff
Plusnet Staff
Fixes: 159
The target SNR is definitely 6db, it goes in 3db steps so 8 isn't one we can choose. The SNR will fluctuate around the margin and that's completely normal.
 Chris Parr
 Plusnet Staff
Fixes: 16
@glloyd
What are your current ADSL stats?
glloyd
That's really odd because it's 8db on boot up and stays solid at 8db same as up is set to 10db so something is not right. And it's the same on what ever router I try.
glloyd
Negotiated Connection Properties
    Receive Direction Send Direction
Max. DSLAM throughput kbit/s 14336 1280
Min. DSLAM throughput kbit/s 7168 32
Attainable throughput kbit/s 15227 888
Current throughput kbit/s 14332 888
Seamless rate adaptation   off off
Energy-saving mode L2 off
Latency   7 ms 8 ms
Impulse Noise Protection (INP)   1 2
G.INP   off off
Signal-to-noise ratio dB 8 11
Bitswap   off off
Line attenuation dB 27 14
Power reduction dB 1 0
Carrier record   A43 A43
glloyd
I spent ages on the phone trying to sort out this merry go round. The agent claims there is no banding on my line yet others say there is. He insisted they do not disconnect when testing the line when Ii said they do. This is what is on the ticket.
"account holder called to ask what his snr margin is and to ask about the dropouts which i have explained this will be down to the testing thats going on
Kind regards,"
It's like banging your head against a brick wall. All I want is the banding removed and my SNR back to what it always has been.
Plusnet Staff
Plusnet Staff
Fixes: 159
Your line *is* banded.
Your target SNR is 6db.
WBC 7M - 14M Medium delay (INP 1) 6dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+)
The testing would only cause a single drop (normally around 3 minutes) at the point we run it, they wouldn't cause the other drops showing:
I've just submitted a request to remove the banding, this will cause a drop, however your line may get banded again if the other dropouts continue.
 Chris Parr
 Plusnet Staff
glloyd
Thank you Chris. I know what the other drops where. As I explained it was due to DNS server problems and me trying to solve it. All back to normal now thanks
