Reset my BRAS profile
- Reset my BRAS profile
- « Previous
- Next »
Re: Reset my BRAS profile
05-02-2008 11:11 AM
Hi Stoley,
It looks like you had a low sync blip back on the second, so I would expect your speeds to improve again within the next 24 hours.
Message 46 of 50
(417 Views)
05-02-2008 11:25 AM
hi stoley, i would take advice from james, but i left my router connected and on all the time even overnight, to try and convince the exchange that the connection was stable.
http://www.kitz.co.uk/adsl/frogstats.htm
http://www.kitz.co.uk/adsl/adsl.htm
try the above links, this will tell you how to get your line stats off your router which may help pn help you.
regards
Andy
regards
Andy
Message 47 of 50
(417 Views)
05-02-2008 12:56 PM
Hello again,
Thanks for replying so quickly Jameseh & martin2006. I collected the line stats off the router which confirm that the downstream rate is being picked up at 2462kbps....
Line Stats:
ADSL Line Type GDMT
ADSL Line Coding INTERLEAVED
Line Attenuation (Down):46 (Up):28
Noise Margin (Down):11 (Up):24
Total Output Power (Down):0 (Up):0
Current Rate DownStr: 2464(K) UpStr: 448(K)
ADSL Line Status UP
FEC(FAST) (Near):0 (Far):0
FEC(INTERL) (Near):408 (Far):3624
CRC(FAST) (Near):0 (Far):0
CRC(INTERL) (Near):6 (Far):32
HEC(FAST) (Near):0 (Far):0
HEC(INTERL) (Near):68 (Far):0
Showtime last(sec) 1202218716
ADSL_FW_Version 0.49
ADSL_Board_Type Annex A
I guess its a 'wait 72hrs' from the blip for BT to re-profile my connection. Hopefully all will be back to normal soon.
Thanks again,
Stoley.
Line Stats:
ADSL Line Type GDMT
ADSL Line Status UP
Thanks again,
Stoley.
Message 48 of 50
(417 Views)
05-02-2008 4:01 PM
will leave you in the hands of pn to unravel those, have you made sure all your filters and cable are ok, and not running near major power souces like multi plugs etc, i also fitted the items below to rule out any problems at my end as best i could.
Link
Link
regards
Andy
[Moderator's note by Barry Zubel: Shortened links as they were distorting the forum a little]
Link
Link
regards
Andy
Message 49 of 50
(417 Views)
09-02-2008 9:54 AM
bought a belking shielded cable from pcworld now to see if it works.
podman
podman
Message 50 of 50
(417 Views)
- « Previous
- Next »
