Reset SNR
sullys666
Reset SNR
This is my current DSL Log
Modulation : ADSL2+
Annex Mode : Annex A/L
Line State : up
Lan Tx : 25360377
Lan Rx : 20773050
ADSL Tx : 19733171
ADSL Rx : 24867077
CRC Down : 0
CRC Up : 51
FEC Down : 0
FEC Up : 96
HEC Down : 161
HEC Up : 0
SNR Up : 11.2
SNR Down : 9.5
Line Attenuation Up : 7.1
Line Attenuation Down : 11.0
Data Rate Up : 992
Data Rate Down : 15466
and the latest speed test
http://www.thinkbroadband.com/speedtest/button/14675380771923833751-mini.png
Would a reset improve the speed any?
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Reset SNR
Hello there. I would say, possibly. The SNR does seem quite high for your line attenuation. It depends on how your connection looks in terms of stability.
I'll take a look at your account tomorrow when I'm back in the office. Smiley
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
sullys666
Re: Reset SNR
Line attenuation has always been like that the whole time I have been with Plusnet. It has been commented on many times that my speed should be much higher, but it never has been Embarrassed
It's one of the reason's that I haven't changed to Fibre as I have read some many disguntled people using it, that and the Hub One doesn't sound that appealing.
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Reset SNR
@sullys666 I'm having difficulty in finding your account, please could you PM me your username?
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Reset SNR
Thanks for your PM. The connection appears to be stable, so I put through a request to change your SNR target to 6db. The change was rejected by the DLM, though. Sad Your indicative line quality is crimson, so it doesn't seem too good.
I'd probably suggest going through the steps of our broadband trouble shooter at http://faults.plus.net where you can complete it to raise a fault to us if you need to.
 Plusnet Staff
sullys666
Re: Reset SNR
I've gone through the troubleshooter to the best of my ability. It will be interesting to see if anything is picked up.
Fixes: 173
Re: Reset SNR
Testing the connection isn't bringing up anything obvious.
I'm not sure why Anoush's reset didn't go through, but I've managed to put one through to bring the SNR target down to 6dB and seen a slight increase in speed.
I'll link this thread on the fault ticket and leave it open in case our faults guys can see anything I've missed.
 Harry Beesley
sullys666
Re: Reset SNR
I am seeing an almost 2Mbps increase with that reset
http://www.thinkbroadband.com/speedtest/results.html?id=146772497115585781409
Not hopeful that it will stick though as I think the BT lines really need replacing locally, and they need to increase capacity at the exchange ( Unless they are trying to force people on to fibre )
sullys666
Re: Reset SNR
Having run the troubleshooter earlier in the week, I received the follwoing reply today:
I have tested your connection and can see that your line is in sync at 17Mbps which is within the expected range, though there are errors showing as affecting it. To reduce these, I have activated a system called interleaving on your line which should help with any throughput issues.
 Is this a good or bad thing?
Fixes: 16
Re: Reset SNR
That depends on if you are bothered by the fixed amount of extra latency (maybe an extra 10 or 20 ms) due to the interleaving.
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Reset SNR
I think it's a good thing. When Harry reduced your SNR target to 6db, this boosted your speed, but also generated a few errors. My faults colleague has enabled interleaving, which is a form of error correction on the line. It can cause your latency to increase, which sometimes causes a bit of lag whilst gaming.
The only other way to increase your speed would be to look at moving to fibre optic broadband.
 Plusnet Staff
sullys666
Re: Reset SNR
I will see how things go for the moment.  I am sure my son will be the first to let me know if his XBox One lags Wink
Not sure about fibre as I am not sure about the Plusnet provided router being good enough. My DSL-N55U is dual-band and my son has been much happier since he had the 5GHz band solely for his XBox One. Also with the imminent price increases I am concerned Fibre might be too expensive coupled with the telephone package.
Fixes: 173
Re: Reset SNR
While I can't guarantee the Hub One would be exactly what you need, it is dual band so it does have the 2.4GHz and 5GHz bands Wink
 Harry Beesley
sullys666
Re: Reset SNR
...and what sort of price would I be paying? It would need to be Unlimited but doesn't have to be the fastest package.
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Reset SNR
I imagine the standard Unlimited Fibre 38 Mbps would be a quite a big step up from your current package.
I'd suggest calling our customer options team on 0800 013 2632 as they are the best people to provide you with a good deal. 🙂
(They're closed now, though)
 Plusnet Staff
