Reset IP Profile
- Re: Reset IP Profile
Reset IP Profile
01-07-2014 11:30 AM
Hello. You very kindly reset my IP profile last week. I reset my router and there still hasn't been any change really. I used to get 6.9mbps and now I'm getting 5.8. I recently restarted a 12 month contract (as my discounted period ran out) so I don't know if that affected anything. I've also carried out the BT Speedtest thing for you.
Message 1 of 8
(1,129 Views)
7 REPLIES 7
01-07-2014 11:31 AM
what does the BT speedtest Further Diagnostics say and what are the router stats - this explains http://community.plus.net/forum/index.php/topic,96155.0.html
Message 2 of 8
(712 Views)
01-07-2014 11:36 AM
There's an exchange problem in the area at the moment which is preventing us from being able to make any changes 😕
I'll chase this up and see what's going on and I'll review this again for you once cleared.
Message 3 of 8
(712 Views)
01-07-2014 11:43 AM
Thanks Chris, I'll await your response.
Oldjim - Coincidentally, the results diagnosis said something about an error occuring but gave me the result of 5.8mb
Message 4 of 8
(712 Views)
01-07-2014 11:50 AM
No worries. A new Line Card has been ordered for the exchange, it's being fitted today at around 12:30pm
As soon as that's all been cleared (not sure how long it'll take) I'll definitely look into this for you.
Message 5 of 8
(712 Views)
01-07-2014 12:56 PM
It looks as though that's been done and cleared up now.
I've attached some line stats. Your bRAS Profile appears to be set correctly given your sync rate. Your line length matches up with the speeds that you're getting though.
Your Line Quality is showing as red with a low MTBE on the downstream, which shows that your line errors quite a lot. It might be worth swapping microfilters over?
Message 6 of 8
(713 Views)
01-07-2014 1:46 PM
Thanks Chris. What does a line card do in the exchange? If they were replacing it then I guess it was faulty?
Hmmm I can try another microfilter but I've never noticed any errors as such with my connection. If a microfilter doesn't fix it what are the next steps? Also, if I was getting 6.9mb a few weeks ago, is there no way I am going to be able to get that back?
Message 7 of 8
(713 Views)
01-07-2014 2:19 PM
I can try and do a reset on your line but the likelihood is that it'll end back where we are 😕
The Line Card is what a number of customers are connected to. It was likely faulty - I don't have any further information on that unfortunately.
We'll try and get you the best possible speeds, if the microfilter change doesn't help, we can then see what the connection is like in your Test Socket for a day or so?
http://www.plus.net/support/broadband/master-socket-guide.shtml#whatsTest
Message 8 of 8
(713 Views)
