Request to Uncap my U/L speed on 21CN
- Re: Request to Uncap my U/L speed on 21CN
14-07-2012 4:32 PM
if any one from PN is on this forum at the moment can you please arrange to uncap my U/L speed.
I had an incident # 56687616 going back to June 2012, due to a intermittent fault which was eventually cleared by BTW. The line has been pretty stable since then and I have been experiencing D/L speeds of around 1M to 1.3M (this is good since I'm 6.6kM from BT exchange), but I hoped that by capping my U/L speed I might see an increase in my D/L speed.
My U/L speed was capped effective 06 July but as you can see from the figures below the only thing that has really changed is my U/L speed has dropped as a result of being capped. My D/L speed has remained virtually unchanged (down a bit I guess). My SNR has been pretty stablke at around 6bd during the times shown. I also include my current router stats (Voyager 2110).
14/07/12 13:30 Sat 1099 Kbps 365 Kbps 87.114.251.144 1Meg ADSL 2
13/07/12 14:13 Fri 1099 Kbps 366 Kbps 87.114.251.144 1Meg ADSL 2
12/07/12 17:22 Thu 1083 Kbps 365 Kbps 87.114.251.144 1Meg ADSL 2
11/07/12 20:57 Wed 1190 Kbps 366 Kbps 87.113.150.11 1Meg ADSL 2
11/07/12 13:44 Wed 1176 Kbps 366 Kbps 87.113.150.11 1Meg ADSL 2
10/07/12 16:50 Tue 1190 Kbps 366 Kbps 87.113.150.11 1Meg ADSL 2
09/07/12 17:05 Mon 1190 Kbps 364 Kbps 146.90.110.87 1Meg ADSL 2
08/07/12 11:03 Sun 1190 Kbps 366 Kbps 87.115.35.232 1Meg ADSL 2
07/07/12 17:49 Sat 1184 Kbps 365 Kbps 87.113.67.170 1Meg ADSL 2
07/07/12 16:13 Sat 1191 Kbps 366 Kbps 46.208.3.186 1Meg ADSL 2
06/07/12 20:45 Fri 1141 Kbps 366 Kbps 46.208.3.186 1Meg ADSL 2
06/07/12 11:44 Fri 1190 Kbps 366 Kbps 84.93.178.244 1Meg ADSL 2
04/07/12 09:42 Wed 1181 Kbps 545 Kbps 91.125.61.14 1Meg ADSL 2
03/07/12 19:29 Tue 1191 Kbps 545 Kbps 91.125.61.14 1Meg ADSL 2
Router stats :-
Line Mode ADSL2 Line State Show Time
Line Power State L0 Line Up Time 00:00:20:03
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 1354 Kbps 440 Kbps
Noise Margin 5.9 dB 14.2 dB
Line Attenuation 66.5 dB 39.1 dB
Output Power 0.0 dBm 12.9 dBm
MSGC (number in overhead channel data) 12 12
B (number of bytes in Mux Frame) 158 55
M (number of Mux Frames in FEC Frame) 1 1
T (Mux Frames over sync bytes) 1 1
R (number of check bytes in FEC Frame) 16 8
S (ratio of FEC over PMD Frame length) 3.7333 4.0000
L (number of bits in PMD Frame) 375 128
D (interleaver depth) 8 8
Delay 7 msec 8 msec
Super Frames 71642 71640
Super Frame Errors 1 0
RS Words 1289558 4871520
RS Correctable Errors 1369 0
RS Uncorrectable Errors 8 0
HEC Errors 1 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
BT Speed test IP profile (D/L) 1.19 and (U/L) 0.83
many thanks, Ian
15-07-2012 3:06 PM
Just been looking into this and it's a bit of a strange one but I have seen it before. What it is; the BT system currently has your line showing as already uncapped on the ordering process but the MSAN profile is set at 448k. So, the only way to get the uncapped back is to place an order for the line to be capped (which I've just done) and then another one to uncap it again. I know it's a bit odd but it's also probably a much quicker way than going through the fault process.
The order I've just placed will complete on Tuesday, so ask one of the DC guys on Tuesday to place the upcap order for you. This way it'll be done by Wednesday.
Jojo
16-07-2012 2:06 PM
many thanks for that, I have checked now and my BT (D/L) profile is 1.54M but PN profile is 1.2M. Any chance of a nudge up of the PN profile?
Perhaps the line was not really capped before
Ian
16-07-2012 2:39 PM
By the way, as we often get confused over this point, it's only Annex M where the there is a definite sacrifice of a small amount of D/L speed for the extra U/L and Plusnet only offer Annex M on business accounts.
17-07-2012 10:41 AM
anyone from PN on the forum?
If so could you please request an uncap of my D/L speed as per Jojo's comments above. (see related incident number 57674926)
ta.
@Anotherone Thanks for that clarification. Hmmm .... thinks if the BT tester shows U/L and D/L IP profiles on 21CN how come PN IP profile still only shows D/L profile??
Ian
17-07-2012 10:54 AM
my previous message should refer to uncapping my U/L speed, sorry
Ian
17-07-2012 2:18 PM
The order Jojo placed has completed, when trying to place a request to uncap your U/l it is still seeing it as uncapped, as were not seeing the speed for it being uncapped, we'll do an SNR reset on your line to try and rectify this, just want to make sure your connection is stable first, leave your router switched on and I'll check on your connection in the morning.
Chris
17-07-2012 5:14 PM
thanks, will check in on things tomorrow
Ian
18-07-2012 9:41 AM
Having looked at the line I think we'd be best investigating the dropping connections that are causing your slow speeds - latest profile update on your line shows a sync rate of around 1.2Mb when it looks like you should be more used to 5Mb plus?
I suspect that's the main reason you're not showing a better upstream profile to be honest. If you could run through the faults wizard at http://faults.plus.net and raise it as a dropping connection fault (though probably worth mentioning you're in sync below the FTR - Fault Threshold Rate - as well) we'll get it sorted for you. Once that's done we'll get a much better result from the SNR reset Chris suggests above.
18-07-2012 1:48 PM
I'm quite amazed at your comment "latest profile update on your line shows a sync rate of around 1.2Mb when it looks like you should be more used to 5Mb plus?"
Since I have NEVER had any line sync greater than about 1.8M, remembering my line is 6.7kM from the BT exchange.[BUT IF YOU CAN GET ME A SYNC SPEED OF 5M PLUS - TELL ME MORE].
Any disconnections in the past 3 weeks were probably due to me trying to get a BT 2w router working on this line (I failed miserably to get it working). However I did notice on the most recent router stats that the line up count had gone up to 4 overnight?
I restored my trusty Voyager 2110 several days ago and was trying to obtain a higher D/L speed but Anotherone explained quite well why that won't happen on my residential service. So can you please just arrange to uncap my U/L speed, which is all this thread is about.
Sorry but I need to be convinced of the need to raise a fault ticket at this stage, I attach my current router stats for info :-
Line Power State L0 Line Up Time 00:17:38:40
Line Coding Trellis On Line Up Count 4
Line Rate 1285 Kbps 216 Kbps
Noise Margin 6.1 dB 10.3 dB
Line Attenuation 66.5 dB 39.3 dB
Output Power 0.0 dBm 12.5 dBm
MSGC (number in overhead channel data) 11 12
B (number of bytes in Mux Frame) 158 6
M (number of Mux Frames in FEC Frame) 1 16
T (Mux Frames over sync bytes) 1 4
R (number of check bytes in FEC Frame) 16 16
S (ratio of FEC over PMD Frame length) 3.9326 16.0000
L (number of bits in PMD Frame) 356 64
D (interleaver depth) 8 2
Delay 7 msec 8 msec
Super Frames 3800522 3800520
Super Frame Errors 636 0
RS Words 64608890 16152210
RS Correctable Errors 144806 0
RS Uncorrectable Errors 3738 0
HEC Errors 582 0
OCD Errors 19 0
LCD Errors 0 0
ES Errors 0 0
thanks, Ian
18-07-2012 2:10 PM
Quote from: dvvrue95 ......... I have checked now and my BT (D/L) profile is 1.54M but PN profile is 1.2M...........
Out of curiosity how did you manage that (or was it a typo)? Your sync speed on the 14th was 1354 & currently 1285.
18-07-2012 4:56 PM
the BT value came from the BT tester ???? and the PN value came from their website.
What do they say something about "lies and statistics".
Ian
18-07-2012 5:12 PM
Sorry about that, not sure how it's come about.
18-07-2012 7:49 PM
many thanks. I found my router locked up about 15 mins ago, your line reset I guess? Anyway had do do a power down/up without a "graceful" disconnect just for the record. As you say lets see what tomorrow brings
Router stats after reboot, looks like the U/L speed really is uncapped again now :-
Line Power State L0 Line Up Time 00:00:13:59
Line Rate 1545 Kbps 648 Kbps
Noise Margin 6.4 dB 5.5 dB
Line Attenuation 64.5 dB 39.2 dB
B (number of bytes in Mux Frame) 190 40
M (number of Mux Frames in FEC Frame) 1 2
T (Mux Frames over sync bytes) 1 2
R (number of check bytes in FEC Frame) 16 12
S (ratio of FEC over PMD Frame length) 3.9335 4.0000
L (number of bits in PMD Frame) 421 188
Delay 7 msec 8 msec
Super Frames 50157 50155
Super Frame Errors 104 0
RS Words 852672 1705270
RS Correctable Errors 4892 2
RS Uncorrectable Errors 697 0
HEC Errors 89 0
OCD Errors 12 0
LCD Errors 0 0
ES Errors 0 0
cheers (could do with a drink) Ian
19-07-2012 1:07 PM
I'll check later this afternoon but I suspect we won't see any results until tomorrow I'm afraid.
Regarding the disconnection, that seemed to lead to an increase in upstream speed so it might have been that that caused the drop - bit late for the upstream order to complete but sometimes that happens. I'm by no means certain of that though.
