Request to PlusNet to adjust my line please
FIXED- Subscribe to RSS Feed
- Request to PlusNet to adjust my line please
- « Previous
- Next »
Re: Request to PlusNet to adjust my line please
02-08-2016 4:22 PM - edited 02-08-2016 4:23 PM
I doubt it is my brand new BT Home Hub 5 Type B router that I bought is at fault as these routers are known to be the one of the best out there.
So I assume there is something wrong with my line hence I kindly ask PlusNet to investigate my line and please report back findings here. If something is found on my line please fix so this problem does not occur again.
02-08-2016 4:24 PM - edited 02-08-2016 4:30 PM
Testing your broadband now...
[Edit]
Upstream Link Info
Loop Loss | SNR Margin | Errored Seconds | Hec Errors | Cell Count | Speed |
11.1 | 5.8 | 19 | 0 | 39711 | 1128 |
Downstream Link Info
23 | 6.4 | 9 | N/A | 98440 | 15560 |
I'm not able to identify a fault on your line.
The past few days, your sync speed hasn't changed much:
Date | BT Product | Speed | Contention | Speed | Profile | Event |
2016-07-31 15:58:19 | WBC MAX24 mb/s (ADSL2+ Annex A) Uncapped Upstream | 24000 | 13700 | Generic Speed 13700 No Time Out | Speed update by Delta Report | |
2016-07-01 07:59:26 | WBC MAX24 mb/s (ADSL2+ Annex A) Uncapped Upstream | 24000 | 13600 | Generic Speed 13600 No Time Out | Speed update by Delta Report | |
2016-06-30 16:03:21 | WBC MAX24 mb/s (ADSL2+ Annex A) Uncapped Upstream | 24000 | 13500 | Generic Speed 13500 No Time Out | Manual Change | |
2016-06-29 22:52:45 | WBC MAX24 mb/s (ADSL2+ Annex A) Uncapped Upstream | 24000 | 13200 | Generic Speed 13200 No Time Out | Speed update by Delta Report |
@very452001 Are you connecting wirelessly or via a wired connection?
02-08-2016 4:41 PM - edited 02-08-2016 4:42 PM
Thanks for the results.
I'm connected by wired not wireless except for mobile phones and tablets obviously.
24-11-2016 12:41 AM
Recently again I had same problem were speeds went super slow then I did that suggestion which is disconnect/reconnect on the router page and speeds went back to normal.
What profile am I on at the moment?
24-11-2016 10:02 AM
Hi. I switched to Plusnet just one week ago after 8 years with TalkTalk.
Beginning to think I made a big mistake, since the recent packet loss issues badly affected our gaming and Netflix service and now the line speed has also deteriorated.
It was supposed to be 'up to 17MBS' download speed, we are getting around 6MBS.
If this continues much longer then as far as I am concerned the service contract has not been fulfilled and I will be switching elsewhere.
- « Previous
- Next »
