Request for connection graph
- Re: Request for connection graph
19-02-2014 12:14 PM
Could someone from plusnet please post a graph of my connections over the past week.
I seem to be having irregular but increasingly frequent disconnections that are unrelated to phone use or the weather.
many thanks
many thanks
Message 1 of 6
(717 Views)
5 REPLIES 5
19-02-2014 12:48 PM
Hi tagaloa,
Here's your connection graph:
<img src="http://community.plus.net/visualradius/generated/image13928140366282.png"/>
It might be worth having a read through http://community.plus.net/forum/index.php/topic,119921.0.html
Please let us know if we can be of any further help.
Message 2 of 6
(464 Views)
19-02-2014 1:09 PM
Thanks for that. I don't know what else you can do at the moment.
I suppose there is always a slender chance that it will disappear as mysteriously as it started.
We have made no changes to our wiring that could explain its sudden appearance, so that leaves failing hardware at our end. Later this afternoon I'll pick up a replacement phone socket with built in filter and replace the one that is currently in use, just in case the filter is failing. After that it's a matter of tracking down a spare router to test it with.
Message 3 of 6
(464 Views)
19-02-2014 2:33 PM
No problem.
Before you do that, it might just be worth trying the router into your Test Socket in the first instance. Although you've not changed anything with regards to your internal wiring, it can become degraded over time which may have an effect on the quality of service you experience.
Message 4 of 6
(464 Views)
19-02-2014 3:16 PM
Unfortunately it's old wiring and there is no test socket.
Message 5 of 6
(464 Views)
19-02-2014 3:52 PM
Ah - Ok. You could try an alternative microfilter if you have spare before installing a new faceplate.
If you'd prefer to go ahead and install a new socket instead, that's of course up to you
Message 6 of 6
(464 Views)
