Request for IP profile reset
- Request for IP profile reset
07-06-2016 10:56 PM
I recently had a wiring problem with my phone line, which has been resolved now.
As a result of correcting this I see that my line is now reliably in sync at about 5 Mb/s higher then it was before downstream and about 400 Kb/s higher on the upstream.
It has been in sync with no resets or other issues for several days now, but the IP/BRAS profile is not changing.
Is it possible for a member of PlusNet staff to reset the profile for me please so that it can increase to be closer to the sync speed? I know it won't be the same but is about 5 Mb/s out at the moment.
This is an ADSL 2+ line
Re: Request for IP profile reset
08-06-2016 9:18 AM - edited 08-06-2016 11:23 AM
20-06-2016 11:52 PM
Did you get my PM?
21-06-2016 12:26 AM
Hi there. You maybe able to check this yourself - Sorry if these are obvious questions to you, but how do you know the IP/bRAS profile is not increasing - Have you run the BTw Diagnostic test to check it at all?
As you are on ADSL2+ it should increase immediately there is any increase in sync speed, and it should 0.882 x your sync speed from your DSL stats.
Another possible issue is that your Current Line Speed may not have increase if the BT Servers haven't sent an updated Delta Report to Plusnet's systems. It should be the same as the BT IP Profile (rounded down to the nearest 0.1).
21-06-2016 9:13 AM
Matthew hasn't been in the office for the last week. However if this is the account I've found then we're profiling it at 15.7Mb/s right now. It's syncing at 17906, so that's correct.
21-06-2016 11:43 AM
21-06-2016 11:46 AM
Where are you seeing a profile of 800? Is this on a BT speedtest?
21-06-2016 11:49 AM
21-06-2016 11:51 AM
OK, it looks like you've been connected solidly for 13+ days. Can you try a single disconnect/reconnect and see how that goes?
22-06-2016 12:16 AM
Just tried that - that seems to have reset the noise margin to 6 dB, where it was 3 before and thus resulted in a slower sync on downstream, though up is the same.
22-06-2016 12:55 AM
The upload IP profile shown is just a number provided to fill a slot on the page, it isn't used to regulate data transmissions. The value of 832mbp shown is a legacy setting carried over from ADSL Max. It means upstream is uncapped. Data will transfer at up to sync speed (less overheads).
22-06-2016 9:00 PM
As spraxyt has said, the IP Profile shown by the tester for upstream isn't the real profile and your upstream sync speed is pretty well flat out for ADSL2+, so you shouldn't have an issue there.
If your sync speed was banded to 888, then this might have indicated an issue with errors being high. Some exchange line cards band the speed to 888 when Interleaving is used and the depth is increased.
25-06-2016 3:25 PM
Thanks for all the replies. I will do some more testing on the upstream speeds.
Is there a way to have the target noise margin reduced to 3 dB now that the line fault has been corrected though? It's at 6 dB right now.
25-06-2016 3:29 PM
Although one of the Plusnet Help Team might be able to get this done, it's not very common, I suspect that they will likely say that you are best waiting for DLM to lower it, which it should if errors are low enough.
