Request for ADSL2+ with capped upstream
Fixes: 22
I would like my line to be set for ADSL2+ with capped upstream. I think that would be better than its current strange ADSL1 with uncapped upstream mode.
Current line stats:
[DSL Modem Stats]
        US Connection Rate:    640    DS Connection Rate:    2752
        DS Line Attenuation:    57.5    DS Margin:              9.0
        US Line Attenuation:    31.5    US Margin:              11.0
        US Payload :            212293344      DS Payload:            3013981056
        US Superframe Cnt :    12845126        DS Superframe Cnt:      12845127
        US Transmit Power :    0      DS Transmit Power:      0
        LOS errors:            0      SEF errors:            0
        Errored Seconds:        0      Severely Err Secs:      0
        Frame mode:            3      Max Frame mode:        0
        Trained Path:          1      US Peak Cell Rate:      1509
        Trained Mode:          3      Selected Mode:          1
        ATUC Vendor Code:      54535443        ATUC Revision:  3
        Hybrid Selected:        3      Trellis:                1
        Showtime Count:        7      DS Max Attainable Bit Rate: 2752 kbps
        BitSwap:                1      US Max Attainable Bit Rate:    n/a
        Annex:                  AnxA    psd_mask_qualifier: 0x0000
        Power Management Status: L0    DS HLINSC: 0
        US ACTPSD:              -345    DS ACTPSD: -355
        Total init. errors:    0      Total init. timeouts: 0
        Showtime init. errors:  0      Showtime init. timeouts: 0
        Last showtime init. errors: 0  Last showtime init. timeouts: 0
        ATUC ghsVid:  b5 00 54 53 54 43 05 10
        T1413Vid: 00 00        T1413Rev: 00            VendorRev: 00
        ATUR ghsVid:  b5 00 54 53 54 43 00 00
        [Upstream (TX) Interleave path]
        CRC:    11      FEC:    1088    NCD:    0
        LCD:    0      HEC:    272
        [Downstream (RX) Interleave path]
        CRC:    1271    FEC:    41209  NCD:    0
        LCD:    0      HEC:    0
"Trained mode: 3" indicates G.dmt aka ADSL1. I think the target SNRM is 9 mainly for historical reasons, the line used to run much slower until I disconnected the bell wires about 3 years ago. And the only time the SNRM was reduced from 12 to 9 was after the line was accidentally running on ADSL2+ a while ago.
I also have a wildly optimistic estimate of 4.5Mbps from BTWholesale, which is estimating ADSL2+ will be 50% faster!
1 REPLY
Fixes: 78
Re: Request for ADSL2+ with capped upstream
I've just raised order 1-16281329028 for you, that should complete tomorrow.
Adam
 Adam Walker
