Request: SNR Reset
Lee0101
Request: SNR Reset
I had some internal wiring problems which nudged the target SNR to 9db.
I think the line has settled down now so can I request a target SNR reset back to 6db please?
Also, looking at my router stats I've noticed the Interleaver Depth is set at 1 which I read is exactly the same as having Fast Path switch on; is this correct?
Lee
Fixes: 160
Re: Request: SNR Reset
Sorry for the delayed response, looking at this now.
 Chris Parr
 Plusnet Staff
Fixes: 160
Your target SNR is 6db already, with interleaving off for your line.
The line is banded at the moment though, so you won't get any speeds higher than 9Mb/s until that's removed. I've removed it, but with the line quality showing as RED I'm not convinced that it won't get re-added again.
 Chris Parr
 Plusnet Staff
Lee0101
Hi Chris, the line stats now show the SNR is hovering around 6db since you removed the banding but I didn't realise the line quality was that bad when you say it's showing red; no crackling and minimal noise on the line so maybe there's still problems with the internal wiring somewhere.
The thing is though, not too long ago I managed a record line-sync time, I think it was around 100 days or something with no noticable problems even with the SNR dipping under 6db quite a bit, especially at night.
Hopefully the line will stay stable now.
Thanks for your help Chris.
Lee
