Request: Line Profile Reset
darkcircuituk
It appears that BT (Openreach)  have finally resolved the problem with noise on the line, however my once blisteringly fast 3mbps has now dropped to around 0.1mbps. I politely request that my line profile is reset in the hopes that I might once again reach the dizzying heights of 3mbps.
Thanks!
Fixes: 162
Re: Request: Line Profile Reset
Taking a look now, sounds like you're aware that the phone fault has likely impacted the broadband so let me see what we can do.
 Chris Parr
 Plusnet Staff
darkcircuituk
Oh trust me, I'm fully aware that this is BT's (Openreach's) fault, it usually is  Wink
Thanks for having a look
Fixes: 162
I've reset the line, but need to give your profile a nudge on our systems but they are running a tad slow at the moment, I'll sort that as soon as I can.
 Chris Parr
 Plusnet Staff
darkcircuituk
Thanks very much for all your help Chris, so glad I chose plusnet for my ISP Smiley
Fixes: 162
If you disconnect/reconnect you should see an improvement in the speeds again.
 Chris Parr
 Plusnet Staff
darkcircuituk
Thanks Chris I've done that, crossing my fingers my line remains relatively noise free Smiley
